Ana içeriğe geç
Proper cleaning of the logic board for iPhone 6 Plus
Good Afternoon,
I'm reassembling my iPhone 6 Plus and as I'm about to put in my logic board I thought I should clean it like I have all other parts for this rebuild. What is the safest way to clean any dirt or dust that may be stuck to it and are there any areas to the logic board that should not be touched or wiped in any way that are possibly too delicate? I want to make sure that I don't damage anything that wasn't damaged before especially due to something that was because of my lack of knowledge and for which I could have avoided.
Thanks Much for any advice on this. Your time is greatly appreciated!
-Brittney
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
I use in my work 99% isopropyl alcohol and tooth brush, better is some soft brush or some paining brush. Alcohol will not damage any component on the main board. Only be carefull with cameras and microphones.
Bu yanıt yardımcı oldu mu?
Puan 2
1 Yorum:
Okay, Great! Thanks that helps me a lot. How much of the 99% isopropyl alcohol should I allow to cover the logic board when brushing away dirt with a soft brush? Is there a too much or a too little? In other words where would be a good place to apply this technique between a very fine mist of alcohol over the board and then lightly brushing away any dirt to just placing it in a small bowl filled with the alcohol to soak and brush from inside the bowl?
tarafından
Yorum Ekle
Yanıtını ekle
Missbritt486 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 5
Her zaman: 101
