Ana içeriğe geç
22 Eylül 2017'de satışa sunuldu. Model A1863, A1905 olarak tanımlanıyor. GSM ya da CDMA olarak 64 ya da 256 GB kapasitelerinde, Altın, Gümüş, ve Uzay Grisi renklerinde satılır.
Battery hitting the display
I just replaced my battery and the new battery hits/crushes the display, causing some discoloring along the cracked part of the display.
The 1st image shows the display is properly attached to the chassis of the phone, while the 2nd image shows the display is removed/unscrewed (P2/Pentalobe Screw) from the chassis.
There's also some discoloration/white streak around the browser's forward button in the 1st photo, but not present if the display is unscrewed from the chassis, shown in the 2nd photo.
Is it because the glass is shattered so I have a clearance issue or is it the battery?
PS: The battery is slightly taller than the Taptic Engine and speaker, and almost as tall as the logic board.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
the technician that installed the battery likely left the adhesive from a previous or original battery install. this adhesive is also like rolled or gummed up compounding this issue. it also appears like one or several of the following screws are not fully tightened down.
make sure these are down all the way (don't use excessive force just check that they are not loose)
also investigate if the frame of the phone is bent. You can do so by laying in back down on a flat surface like a table and seeing if it rocks if when you "tech deck it" reference the image below make sure the camera bump hangs off the edge so there is no high or low spots.
fix:
  1. unscrew and remove the hold down plate for the LCD and battery flex cables
  2. unplug the battery
  3. unscrew and remove the face id flex plate cover then unplug it
  4. unplug and remove the display assembly
  5. remove the battery
  6. clean up the adhesive under the battery itself
  7. replace both screen and battery
  8. for a guides with details for both processes From IFIXIT linked here Screen repair guide : battery replacement guide
iPhone 8 Battery Görseli
Kılavuz
iPhone 8 Battery Replacement
Zorluk:
Orta
30 minutes - 2 hours
iPhone 8 LCD and Digitizer Görseli
Kılavuz
iPhone 8 LCD and Digitizer Replacement
Zorluk:
Orta
45 minutes - 2 hours
Bu yanıt yardımcı oldu mu?
Puan 0
2 Yorum:
they said they replaced the battery, so no tech fault
tarafından
The battery adhesives have been completely removed. Everything has also been screwed tight and the frame/chassis of the phone is straight, but I'm still getting the same issue.
tarafından
Yorum Ekle
Yanıtını ekle
Myles Earvin Uy sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 9
Her zaman: 111
