Ana içeriğe geç
Extremely low volume on all settings
When I start the CD player or radio the volume ist almost inaudibly low. It doesn't increase with setting for volume.
It's a Sony CFD-S05 model casette, cd and radio.
Bu iyi bir soru mu?
Puan 3
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
So I found the solution. In my case the capacitor C303 by the side of IC301 on the mainboard was getting super hot and the chip didn't get the voltages it needs. After replacing it with another capacitor of the same voltage rating and capacity (100µ,10V (105°C)) but with higher temperature rating, the device works perfectly again.
If anybody has the same problem, this Sony CFD S05 SM document helped me to understand which chip is involved in determining the volume and where to look.
Bu yanıt yardımcı oldu mu?
Puan 2
3 Yorum:
Hi, I had the very same problem but with the CFD-S07CP model and this solution fix the volume issue. Thank you so much for the info.
tarafından
Thank You very much! Replace capacitor C303 saved my device too.
tarafından
Mein Problem mit Sony CFD-S05: die Lautstärke ist etwas reduziert und der Ton ist verzerrt. Hat jemand einen Tip?
tarafından
Yorum Ekle
Yanıtını ekle
Pelle Tuulison sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 31
Her zaman: 930
