Ana içeriğe geç
10.1 inçlik Galaxy Tab tabletin üçüncü nesli.
LCD screen Ribbon Connector
Hi,
So i have a random question. I had a broken samsung tab 3 and iv taken it apart for a project. I wanted to know is there a way to change the Ribbon Connector to a 40pin? Or is there away of taking the gray tap (not sure whats its called) to put a 40pin ribben cable to it and complete void the LCD board.
Update (06/23/23)
Resim
Hi sorry about that.
Im wating to reuse it for a rasberry pi by installing a Display Monitor Driver Board
Bu iyi bir soru mu?
Puan 1
1 Yorum
@learning201 the board we are looking at is the LCD driver board? Connected to your display panel? What is the exact model number for your tablet (GT-P5200?)
By using the display connector schematic, could you not determine which pin does what and move on from there.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
if you add photos and the reason why you want to change to 40 pin then it will give people a better understanding of what you are trying to do
Update 06/23/23
@learning201 you would need to find out what each pin is for, some will be ground, others could be for single rails or you could have 2-3 pins connected to 1 rail
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
Learning201 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 12
Her zaman: 405
