Ana içeriğe geç
64 veya 256 GB depolama alanı seçenekleriyle sunulan, 9. nesil Apple iPad (Wi-Fi) için onarım rehberleri, söküm ve sorun giderme bilgileri. Eylül 2021'de piyasaya sürülmüştür. A2602 model numarası ile tanımlanabilir.
Charging port not working
How do I find someone to replace a charging port on an iPad 9th generation?
It was working when it fell off the bed.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 3
Yorum Ekle
3 Cevap
Filtre ölçütü:
En Yararlı Yanıt
First of all, if you're looking for suggestions you'll need to tell us where you're located, as this is a worldwide site and the answer will be very different depending where you are.
Until then, all I can say is you're not in a good position here. Apple did you dirty on the charging port of your iPad; not only is it attached directly to the motherboard so you can't just replace a part, but they also put it on a flex cable, making it even harder to replace. So it's going to take a fairly skilled technician to be able to do the specialized soldering required to fix your port.
You can always do a search for local repair facilities and contact them. Ask whether they have the expertise to repair your port, and what the cost is.
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
it stopped working then i had to fix the charging port.
Puan 1
1 Yorum:
Same. I Suggest To get an IPAD 9 Lightning Replacement.
tarafından
Yorum Ekle
ipad 9 no charging flex change ic change no charging
Puan 0
Yorum Ekle
Yanıtını ekle
Dan Frain sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 14
Son 30 gün: 47
Her zaman: 1,836
