Ana içeriğe geç
Samsung'un orta segment akıllı telefonu. Uygun fiyata iyi performans. Model numarası: SM-A530F
when charging the phone says moisture detected
when i charge my my phone the phone says moisture detected,i don't live in a humid environment and i don't remember dropping my phone on some water,i tried cleaning the usb port but it didn't work. what should i do?
(sorry for my broken english)
Update (06/07/24)
for anyone wandering it is a software issues
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
@senopatib first try this. Turn your phone off. Then connect the charger. See if it does now charge. if you are sure that there is no moisture in the USB port and if you already cleaned it with isopropyl alcohol etc. it is time to replace the port. Of course, on this phone the port is soldered to the logic board which would require some board level soldering. If this is above your level of comfort, consider getting in touch with somebody who does board level repair. Check https://www.youtube.com/watch?v=0ZjDjt6Y... as well before working on it. This video shows you how to replace the port. It's not as easy as the video makes it seem. It'll take some experience to do the soldering.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Senopati B. sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 10
Son 30 gün: 23
Her zaman: 684
