Why is my laptop beeping continuously?
I tried to turn on my laptop and found my laptop beeping continuously.What should I do to fix it?
Bu iyi bir soru mu?
Bu iyi bir soru mu?
You should try checking with this HP guide. Your problem might vary from a dead CPU, to a simple reset. I've had similar issues with some Lenovo machines and the issues was solved with a simples reseat of the RAM. Good luck.
Bu yanıt yardımcı oldu mu?
None of them helped
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 49
Her zaman: 570
4 Yorum
Hello, are the beeps in a sequence by chance, or is it just one long beep? If it is a sequence if you could count the beeps and reply that would be great!
BurtBen tarafından Paylaş
No it's actually beeping like a car's blinker
Jackson King tarafından Paylaş
Could you possibly record it and add it to the post?
Not sure how?:
Mevcut bir soruya görsel ekleme
The beeps could indicate a fault. The number of beeps, as BurtBen suggested a recording, might help us diagnose the issue.
How old is the laptop?
JnCA tarafından Paylaş
