Ana içeriğe geç
AC power adapter for MacBook, MacBook Pro, and MacBook Air. Uses a self-aligning magnetic connector that disconnects safely when tugged. First-generation (2006-2012) MagSafe chargers have a slightly thicker, L-shaped connector. Available in 45 W, 60 W, and 85 W versions.
65 Soru Tümünü görüntüle
Replacing Magsafe "T" connector with an "L" connector
Hi,
I have a Magsafe 85W with a broken T connector, and I have a Magsafe 85W with an L connector but a failing power supply.
So I want to replace the broken T connector with my other L connector.
It would be ok to join both cables in the same order, the inner cable of the T power supply, with the inner cable from the L connector, and the outside cable with the outside cable from the L connector?
Thank you!
Esteban
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
Sure. I interchange them all the time.
Bu yanıt yardımcı oldu mu?
Puan 5
1 Yorum:
Thank you for answering, it's working perfect.
tarafından
Yorum Ekle
Like the previous answer. Connect the inner cables together and the outer cables together. I just did it and it works perfectly.
Puan 0
Yorum Ekle
Yanıtını ekle
Esteban Eid sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 4
Son 30 gün: 6
Her zaman: 9,021
