Ana içeriğe geç
2005 yılında piyasaya sürüldü. Model numarası: PP11L, Giriş: 19.5V ~ 4.62A.
Laptop Power up With Total White Screen
My Dell Latitude D610 Power Up with White screen.
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
3 Cevap
Filtre ölçütü:
Seçilen Çözüm
here is a link for you to download the service manual for your computer.
http://support.dell.com/support/edocs/sy...
Bu yanıt yardımcı oldu mu?
Puan 1
1 Yorum:
ITs a white srceen wont open
tarafından
Yorum Ekle
You can fix this issue by performing a full system restore and your data and files wont be deleted.
There are two ways to perform system restore:
Open start menu click run and then type cmd to open command prompt.
Type CD.. to make c:\ only.
Type CD windows then CD System32 and then restore.
After once you find yourself in c:\ windows\system32\restore>
Then type restrui.exe press enter.
Once the system restore window open then click next to select any available restore point.
This process shall take couple of minutes to perform restore and please make sure that once
this process started it wont be reversible and neither you will lose any personal data.
Other way to perform system restore is to open safe mode by clicking F8 on start-up and
check safe mode option then further a dialogue box will open to ask for system restore and
then follow the above steps. Thanks
Puan 0
Yorum Ekle
White screen or black happens usually when carbon creates between RAM and mother board slot. Simply open RAM and clean it properly with paper as well as slot and connect as it was before. Now turn on your computer it will start working.Thanks.
Puan -1
Yorum Ekle
Yanıtını ekle
naveed sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 3
Son 30 gün: 12
Her zaman: 3,677
