Ana içeriğe geç
Kasım 2020'de piyasaya sürülen 13" MacBook Pro, Apple'ın 8 çekirdekli CPU ve 8 çekirdekli GPU'ya sahip Arm tabanlı M1 SoC'sini içerir. (Model A2338 / EMC 3578, iki adet Thunderbolt 3 bağlantı noktası ile)
Why my speakers stopped working?
Hi. I bought a used Macbook Pro M1 2020 used one, apparently in very good condition and great battery and all. After 1 week of usage the speakers stopped working, but Headphones jack is working fine, I tried to clean it up and but no luck. Tried all other troubleshooting steps, even opened it up and reconnected the flex cables but nothing happened. Before speakers stopped working there was very little crackling sound coming sometimes. So should I get speakers replacement?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Sounds like the Audio board needs replacing. Review Apples service guide here 13” MacBook Pro M1.
Bu yanıt yardımcı oldu mu?
Puan 1
24 Yorum:
Hi Dan, thanks for the reply. Could you please help me with the part number I could find 923-05048/49, this is the audio flex assembly, it's should be replaced?
Regards
tarafından
Hey Dan, the tech guy called he says some audio section is not working meaning the audio signal is not reaching to the speakers, and he mentioned they'd need to do some "programming" that will format the macbook. Is it right? Please help
tarafından
@alichaudhary - Something is odd here… The speakers and headset socket are analog signals, not digital!
There is no programming other than the volume and balance controls which alters the DAC logics output to the speakers which you can control via the sound preferences settings.
Think of it this way… Your Stereo system outputs are analog to its speakers, the amp offers the controls. Some expensive speakers offer a tuning bridge to bias the bass and treble the speaker unit offers. This is all analog circuits.
Apple often mixes functions. This cable offers the headset jack and within it there is a set of switches which moves the analog output between the headset jack and the speakers.
tarafından
Thanks for your response Dan. So I will tell them not to format/reset my Macbook, correct? They will replace the audio board and hopefully that will bring back the sound, otherwise speakers could faulty, yes?
tarafından
@alichaudhary - A single speaker I could see or both speakers where blown by over driving them.
The volume level and the deep beats in some music can kill your speakers! This is often what people encounter with their stereos when they try to fill a large space for an event with home systems.
So did you push your system too hard? Then I could see the speakers dying! More likely the switch within the socket got messed up. I’ve see a lot more switches failing than speakers.
They don’t need to wipe your drive or alter the OS. If they do you will loose what was on your system. Apps and your data! Unless you backup and have been good about it.
tarafından
19 tane daha yorum göster
Yorum Ekle
Yanıtını ekle
Ali Chaudhary sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 21
Her zaman: 658
