How to fix blue lines on screen
Hi. The screen has a few fading blue lines even when it is off. How do I fix this? It shows a little without light but a lot with light.
Bu iyi bir soru mu?
Bu iyi bir soru mu?
@anhadchugh just going by your description but this sounds very much like a bad display. BlackBerry 7280 LCD ekran ve hoparlör değişimi Post some pictures of what it shows, with your QUESTION. That way we can see what you see.
Kılavuz
Zorluk:
Orta
10 minutes
Kılavuz
Zorluk:
Çok kolay
2 - 5 minutes
Bu yanıt yardımcı oldu mu?
Where can I find a replacement screen?
@anhadchugh that will be the biggest challenge. YOu can try and see if there are any numbers on the back of the LCD screen. If so, use those numbers for an online search. IF not then you have to try to use the BLackBerry 7280 LCD as a search string. You may even have to look at a 7280 that is broken other than the screen. Then harvest the screen from that.
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 11
Her zaman: 265
