Ana içeriğe geç
Sony KDL-50W800C TV; 127 cm ekran boyutuna, 1920 x 1080 piksel ekran çözünürlüğüne, 16:9 en boy oranına ve 4 adet HDMI bağlantı noktasına sahip bir modeldir. Harici bir sabit sürücü bağlamak için 2 USB bağlantı noktası, kabloyla internete bağlanmak için Ethernet bağlantı noktası, Wi-Fi üzerinden internet bağlantısı ve Android işletim sistemi bulunur. Çıkış tarihi: 02.07.2015.
No display no,indication light
Hi,
I have sony w800d tv and i recently replaced it's tcon board because I was having 5 times red light blinking issue. But after 3 days my tv started to blink again but when i turn off the tv then it's not turning on not even the indication light. But when i disconnect the tcon board from main board the tv turn on and when ie my old tcon board, it is also turning on but red light blinking as usual but when I connect new tcon board it is not turning on. Then removed the tcon board and turned on the tv then connect the tcon board after turning on the tv the display turns on and everything is working fine but when i turn off the tv it's not turning on. Help me guys.
Update (07/07/23)
Resim
Resim
Resim
Update (07/07/23)
Resim
It is the old tcon board
Resim
And my multimeter it's a basic one.
Update (07/07/23)
Resim
Is this ok?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
3 Yorum
@sreeramsnair just to clarify, your model is a KDL-50W800D?
tarafından
Yes , w800D .
tarafından
I don't know but when I use my old ( not working) tcon board the tv is turning on blinking 5 times (red) but when i switch to new tcon it is not even turning on the indication light and not even the optical cable input ( a small red light used to be there). But when i turn on tv ( after removing tcon lvdt cable ) and plugging in t back after it the tv shows the display.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
@sreeramsnair could be an issue with the power board or the power to the panel. You will need to check the power connector to the mainboard and see if the voltages are all as listed on the board. We would need to see your boards. Post some good clear well focused images of your boards with your Question.
Also, Sony requires a firmware update with some of their boards. If you can go into your settings and see if you can determine which firmware/software version your TV is.
Adding images to an existing question - iFixit Repair Guide
Update (07/07/23)
@sreeramsnair I just noticed the number on your replacement T-con board. In order to use it, you will have to block off the last 14 pins on the connector. Take a piece of tape and apply that over the last 14 pins of the cable. That way it can't make contact and should work as it is supposed to. If the 5 Blink error on your TV is the T-con board.
Resim
Do not apply the old metal shielding over the T-con board. It will not fit and it will shorten out your board. You need to find an alternative way of mounting it. I use Velcro on some of my fixes. Check this guide Evrensel Arka Aydınlatma İnvertörü step 14 to see what I mean.
Display Görseli
Kılavuz
Zorluk:
Orta
1 hour
iFixit Görseli
Kılavuz
Mevcut bir soruya görsel ekleme
Zorluk:
Çok kolay
2 - 5 minutes
Bu yanıt yardımcı oldu mu?
Puan 1
19 Yorum:
I'm kinda beginner in this field so don't tell any complicated words just simple 😅
tarafından
tarafından
@sreeramsnair both T-con boards identical? Same numbers and same version? Do you have a multimeter?
tarafından
No , I have given my tv for repair and they replaced the tcon board with same model number but it only work for one day and next day it was showing same problem ( 5 times red light blinking) then i ordered different tcon board T430HVN01.6 CTrtl BD it don't have 3d support but other things all fine but like one week later red light start to blink i turned off the tv then boom nothing turning on and i now here😂
tarafından
Yes sir , I have a multimeter.
tarafından
14 tane daha yorum göster
Yorum Ekle
Yanıtını ekle
SREERAM S NAIR sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 21
Her zaman: 1,009
