I want to uograde the CPU and GPU
it uses the sane socket si maybe it is possible and i want to add dedicated GPU there is a slot for it then i might as well upgrade the cooling system..
Bu iyi bir soru mu?
Bu iyi bir soru mu?
@akiradokkabei have you opened your laptop up and checked the motherboard. It is my understanding that the CPU and GPU are soldered to the board. Sure it can be done, if you have the tools and the skills. Also, you need to make sure that your motherboard chipset supports a dedicated GPU. It's definitely not plug-and-play.
Bu yanıt yardımcı oldu mu?
actually i am just doing this for fun...The board is pretty much cheap since its a trash APU.
@akiradokkabei I see. Well in that case you got a good board to practice some soldering skills :-) Not sure if you want to go ahead and waste a CPU or a GPU on a "trash APU"
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 26
Her zaman: 157
