Ana içeriğe geç
Nintendo Switch için resmî lisanslı Joy-Con alternatifi. Eylül 2019'da piyasaya sürülmüştür ve NSW-182 ve NSW-182U model numaralarıyla tanımlanır.
Random drift on left controller
On my left hand controller it is just steering left and it was so random in just started happening if there is a way to reset it or something that would be nice thank you.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
3 Cevap
Filtre ölçütü:
If the analog sticks are not responding correctly, Hori recommends the following solution in the manual for the Split Pad Pro Attachment Set:
The Split Pad Pro Attachment Set is not compatible with the Nintendo Switch calibration menu.
In the case that the accessory's dedicated recalibration option does not work, it's possible that you have control stick drift. The solution in that case is the cleaning of the potentiometers or a replacement of the control stick module. A reference for disassembly is provided here.
I hope that your problem is solved in a quick and simple manner.
Bu yanıt yardımcı oldu mu?
Puan 0
2 Yorum:
This doesn’t tell you how to actually get to the potentiometer
tarafından Paylaş
If by potentiometer you are referring to the joystick, then sure it does. See the big red nob in the pictures. This joystick can be unsoldered from the board and replaced with one compatible with a Xbox. You aren't going to disassemble the joystick to get to the internal potentiometer.
tarafından Paylaş
Yorum Ekle
Drift is a common problem with all joysticks. The best way to solve that problem with with a joystick replacement. The Hori Split Pro appears to be compatible with Xbox joystick replacements like can be found anywhere you search for "xbox joystick replacement". For example: https://a.co/d/5AmYLY1
Puan 0
Yorum Ekle
necesito encontra el repuesto del joystick de ambos controles ya que el drift es horrible, saben donde encontrar el repuesto
Puan -1
1 Yorum:
Seguramente cualquier reemplazo de joystick de Xbox funcionará. La distribución de pines es exactamente la misma. Por ejemplo: https://a.co/d/5AmYLY1
tarafından Paylaş
Yorum Ekle
Yanıtını ekle
Issac sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 19
Son 30 gün: 72
Her zaman: 4,958
