Hoverboard not turning on
Have green lights on charger till I plug into hoverboard and lights go out can anyone help me 🙏
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Could be the battery. If you don’t charge it very often then the battery can lose charge and if it drops below 30 volts the bms won’t accept a charge. Will probably need a new battery. Open it up and check the battery voltage with a multimeter.
Bu yanıt yardımcı oldu mu?
Battery capacity is 25.2v, tested capacity is 24.7
You need a new battery as it's gone below voltage I'm afraid.
Thanks for that, will look for new battery 🤔👍
Do you know best place to get one from???
Battery is charged and ,each time I press the start button it kills the Battery of 8 volts in one jolt and won't turn on , with no signs of damage on the mother board or any components withing the unit .
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 28
Her zaman: 959
