Why my car has problem with the injection
It say check injection and some time slow down from 100 to 60
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Sounds like either your injector pumps are starting to go bad or it could be reading bad injector codes because your breather filter needs to be changed.
Bu yanıt yardımcı oldu mu?
I had the same problem, and checked it with ODB which said to "change the petrol heating sensor"
# I fuel it with High Efficiency petrol 2 times, and got better.
# Then I fuel it with 85% petrol and 15% benzine ( hoping to "clean" the injectors) and got better results.
Anyway it's an old car, but I think is better to check and if it need, change the injectors.
Sa peut être le mano HP ou les injecteurs qui ne va pas il faut un scanner pour être sûr
Son 24 Saat: 1
Son 7 gün: 17
Son 30 gün: 86
Her zaman: 1,244
@hliasmoust12265 if you scan your OBD II, what exact error code do you get? "Check Injection" is just way too broad to do anything with it.
oldturkey03 tarafından
I gave it to mechanic he pluged it and he didn't show anything...this happen when im in a hill after that its normal
hlias-moustafa giounes tarafından
@hliasmoust12265 so this only happens when you go uphill? does that mean anytime your Renault has to work hard, you get a "Check Injection" error?
