Ana içeriğe geç
Samsung yazıcılar için onarım ve sökme kılavuzları.
paper feed rollers out of adjustment?
My Samsung laser color printer CLP 600N gives me a 'paper jam' error but there is no paper jam. In researching I ran across a blurb about always gently/easily pulling paper out of a printer when it jams be/c if you yank it out you can mis-align the rollers. The error message started after I cleared a jam by jerking the paper out of the rollers. Anyone know how to re-align these rollers?
Bu iyi bir soru mu?
Puan 1
1 Yorum
I am using a SAMSUNG SL-M2020W to print cheques. The Cheques are placed in Landscape position. The issue I am having is that the texts are not parallel to the edges. It used to be good. The paper feed rollers seem to grip more on one side make the cheque mis-aligned while printing.
How do I fix that ?
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
Carolyn Hardy, I checked the service manual and do not see much in the way of adjustments. You can download it from here . Seems like there are a few other reasons that could do that. Check the sensor listed in the manual:
"1) Jam0 (Jam in feed area)
  • After a page was picked up, it was not fed.
  • Paper does not reach the feed sensor in a certain time.
  • Feed sensor is faulty and does not detect paper.
- FCF pickup error: When a paper is not picked up in the 1st cassette.
- SCF pickup error: When a paper is not picked up in the 2nd cassette.
2) Jam1 (Jam inside printer)
  • After the leading edge of the paper has reached the feed sensor, the feed sensor doesn't turn off (fails to detect the trailing edge
of the paper) in a certain time
  • After the leading edge of the paper has passed the feed sensor, it doesn't reach the exit sensor in a certain time.
  • Exit senor is faulty and does not detect paper.
3) Jam2 (Jam in exit area)
  • After the leading edge of the paper has passed, the trailing edge of the paper has not passed the exit sensor within a certain time
  • The paper drive motor has been driving for longer than the time needed for the longest paper size and the exit sensor is not off.
5) Jam MPF
  • Paper could not be picked up from the MPF tray.
  • After pickup, a paper has been fed, but it doesn't reach the feed sensor in a certain time.
The other option you have, is to check on this site http://www.fixyourownprinter.com Hope that this will at least get you started.
Bu yanıt yardımcı oldu mu?
Puan 3
1 Yorum:
First of all I want to appologize for not answering sooner. I thought any answers to my question would be forwarded to me. Now I know I have to come back to the website. Anyway. Thank you for your answers I will check them out and see if I am able to do them. I had the service manual for this printer already but as I recall when I tried to read it I got a headache. Your answer is much easier to understand so with that I will try the manual again. Thank you for the link to the other page as well.
tarafından
Yorum Ekle
Hi There,
You did mention that there was a paper that had jammed, but you have removed the sheet.
Did you get the full sheet out, or did the sheet tear while you were pulling it out.
if it did you may have a piece of paper jammed between the rollers, near the paper sensor.
a careful inspection my help you determine the case.
can you post more info about the printer type, make, model etc.
Puan 1
1 Yorum:
I did make sure there is no small piece of paper stuck between the rollers. Sorry it took so long to respond. I didn't know I needed to come back to the website to see any answers I might have gotten. That printer has been sitting here doing nothing for 6 years. Wow.
tarafından
Yorum Ekle
Yanıtını ekle
Carolyn Hardy sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 34
Her zaman: 11,534
