V7 allergy shuts off when I put it on max setting.
My V7 allergy shuts off when I put it on max setting. I have cleaned it very well and put in new filters.
Bu iyi bir soru mu?
Bu iyi bir soru mu?
There is most likely a battery problem. You can try fully charging the battery and see if that resolves the issue. If not, you should purchase a replacement battery. If the issue persists even after replacing the battery, you will need a replacement main body.
I hope this helps!
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 18
Her zaman: 237
