Banging when it spins
Only during spin cycle the machine shakes with loud banging. Barrel seems to be off balance
Bu iyi bir soru mu?
Bu iyi bir soru mu?
If the washer is making a loud noise in the spin cycle, the clutch assembly might be worn out. The clutch assembly makes the connection between the transmission and the inner tub. It is designed to allow the tub to get up to the proper spin speed gradually. As the clutch wears out it may become loud during spin or just after the spin cycle finishes. The clutch is not repairable, if it is loud or not working properly it will need to be replaced.
Bu yanıt yardımcı oldu mu?
could be of balance, or could be something stick under agitator, I just took our washer apart and there was a small sock stuck under there, also take off the side or back panel and there is a small compartment that might have a small rash or sock stuck in it
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 23
Her zaman: 328
