Ana içeriğe geç
Razer Blade 15" Base Model (2020), 10. nesil, 6 çekirdekli ve 5,0 GHz Intel işlemcili güçlü bir oyun dizüstü bilgisayarıdır.
Adding USB-C charging option externally
I've seen some adapters around that connect to Razer's proprietary connector, and was wondering if anyone has attempted to use a USB-C PD board to charge the laptop? I mostly use my laptop portably in Linux without use of the discrete graphics so I only require <100W of power which USB-C can provide. But unsure whether the charging port will accept less than the 230W that comes from the regular charger
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
1 Yorum:
Would love an update on this!
tarafından Paylaş
Yorum Ekle
1 Cevap
Filtre ölçütü:
@lachlanhogan It depends how razer has their power management set up, with other brands such as Dell they force the CPU to throttle a huge amount if it's not connected to the correct power supply, either you'll get lucky or it won't be usable unfortunately.
Thanks! :)
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Lachlan Hogan sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 8
Son 30 gün: 28
Her zaman: 1,149
