Ana içeriğe geç
The Fitbit Charge 5 is a fitness tracker released on August 25, 2021. It adds an ECG sensor, an EDA sensor to measure sweat from your wrist, and an AMOLED display with color
Is this a broken screen?
My Fitbit charge 5 screen won’t turn on. It turns on for a second and then fades back out. I tried the charger reset twice and it didn’t fix the problem. It vibrates when I tap it (sometimes) but it isn’t tracking anything according to my app.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Open your Fitbit app on your phone and see if the watch is connected. Or put it on charge then try it. If it connects take it off charge and see if it disconnects. If it does then as mentioned earlier you probably need a new battery. I have three Fitbit’s, all without a screen and I can test to see if they are on or off this way.
Bu yanıt yardımcı oldu mu?
Puan 4
Yorum Ekle
Hi Abbie,
I don't know enough about your Fitbit to diagnose the problem you're seeing, but I can be fairly confident that it's not a screen problem; the behavior you're describing isn't consistent with either a bad touch screen or a bad display.
I'd lean toward it being a battery issue myself, but you'll probably want someone with a bit more intimate knowledge to check in with first.
Puan 1
Yorum Ekle
Yanıtını ekle
Abbie McCauley sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 11
Son 30 gün: 30
Her zaman: 1,619
