My device not vibration
Bu iyi bir soru mu?
@chupchap could be a bad setting. Go to Settings > Sounds and vibration. Enable the toggle for Vibrate while ringing. If it's on, disable it and then enable it again. Next you want to start your phone is safe mode and check the vibrate motor. If it works in safe mode, it is possible that you have an app on your phone that interferes with its normal operation. You would have to disable each one separate to determine which one this is.
If none of this works then it is possible you have a bad motor. Follow the flowchart to check it out.
Use the search function of your PDF reader to find the components required to test, in this document A70 Component
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 0
Son 7 gün: 9
Son 30 gün: 14
Her zaman: 236
