Ana içeriğe geç
Samsung Galaxy A30s, Samsung tarafından Ağustos 2019'da piyasaya sürülen bir telefondur. Android 9.0 ile gelmiştir.
The volume key is not working
the volume key is not working
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 4
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
  1. Restart your phone: Sometimes, a simple restart can fix minor software glitches that may be causing the volume key to malfunction. Press and hold the power button, then select "Restart" from the options that appear.
  2. Check for software updates: Ensure that your phone's software is up to date. Software updates often include bug fixes and improvements that could resolve issues with the volume key. To check for updates, go to Settings > Software Update > Download and install.
  3. Test in safe mode: Booting your phone into safe mode can help determine if the issue is caused by a third-party app. In safe mode, only pre-installed apps are allowed to run. If the volume key works fine in safe mode, then a third-party app might be causing the problem. To enter safe mode, follow these steps:
  4. a. Press and hold the power button until the power menu appears. b. Press and hold the "Power off" option on the screen. c. When the "Safe mode" option appears, tap on it to enter safe mode. d. Check if the volume key works properly in safe mode.
  5. Clean the volume button: Sometimes, dirt or debris can get stuck around the volume button, causing it to become unresponsive. Use a soft, dry cloth to clean around the volume key carefully.
  6. Check for physical damage: Inspect the volume button for any physical damage. If you notice any cracks, dents, or other signs of damage, it may be the reason for the unresponsiveness, and you might need to take your phone to an authorized service center for repair.
  7. Use on-screen volume controls: Your phone should have on-screen volume controls that allow you to adjust the volume without using the physical buttons. You can access these controls by swiping down from the top of the screen to open the notification shade and then adjusting the volume slider.
  8. Factory reset (as a last resort): If none of the above steps work, you may consider performing a factory reset. Keep in mind that a factory reset will erase all data on your phone, so make sure to back up your important data before proceeding. To perform a factory reset, go to Settings > General management > Reset > Factory data reset > Reset phone > Erase everything.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
Shuaib Abdullahi sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 43
Her zaman: 1,918
