Ana içeriğe geç
Repair information for the Sony Bravia 42" LCD TV. Released in 2012. Model number: KDL42EX440.
Screen goes blank in a few seconds
Sony Bravia 48w600b LCD.
When I turn it on I can see the display for a few moments as it fizzles away. Then only black/dark purplish display. The tv is operating as evident chimes made from the input selection, green power light on of course. Not a connection issue.
Backlight?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
@anthonyant16816 this "black/dark purplish display" should be your backlight. If unsure, either remove the back cover from your TV and see if your back lights are on. You will see those shine through some of the holes in the back cover over the display. Or in a darkened room, shine a flashlight beam at an angle at the screen. See if you can make out any shapes etc.
This sounds more like a panel issue. Post Some good pictures of all of your boards and let us see what you got going on there. Also, check the ribbon cables. Make sure they have no tears, bad contacts, corrosion etc. What does the fizzling look like and do you have any audio.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Anthony Antonellis sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 9
Her zaman: 82
