Ana içeriğe geç
Mitsubishi MMCS NR-242 SD Serisi, Mitsubishi Motors tarafından üretilen ve genişletilmiş depolama kapasitesi için bir SD kart yuvası içeren bir araç navigasyon sistemidir. 2017 yılında yerini Mitsubishi Smartphone Link Display Audio (SDA) sistemine bırakmıştır.
Black screen when updating
Hello,when trying to update, the screen has gone black and does not respond.
Bu iyi bir soru mu?
Puan 1
1 Yorum
The update failed. The screen has gone black. The mitsubishi dealer does not offer me a solution. Well, they offer me to change the screen at a price of more than €7,000 (it's not a mistake... €7,000!). i need an autorun to install the software again. Do you know how I can get it?
Thank you.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Have you turned off the car while the update was running?
Normally the unit should just produce an error code when it fails to update.
Disconnecting the cars' battery for 15 minutes should reset the device and enable you to try again.
Bu yanıt yardımcı oldu mu?
Puan 1
2 Yorum:
Thank you.
tarafından
@carlosberm59725 You should go to an independent repair shop with good reviews and have them take a look at it.
If they can’t fix it you could maybe get them to install a used unit. You can get used units really cheap online and it’s just a relatively standard 2DIN module, so labour cost shouldn’t be too much. They might even be happy to source it for you.
tarafından
Yorum Ekle
Yanıtını ekle
Carlos Bermell Tormo sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 13
Son 30 gün: 39
Her zaman: 785
