How do I identify which fan is for which
my laptop is in need of a replacement fan but i have trouble identifying which is for my gpu ad cpu because i want to buy a replacement part and the fans for gpu and cpu are different.
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Our best bet to tell would to have a look at the inside of the laptop, there are some hallmarks on the heat sinks. The GPU is usually more square, and the CPU is typically more rectangular. Depending on which GPU is in your machine, the GPU is also larger.
If you want to know for certain, remove the heat sinks. The actual CPU, or more likely the GPU, will have some manufacturer markings you can use to identify.
Bu yanıt yardımcı oldu mu?
Thanks ! That helped
@ghostrecon2497 Awesome! Let us know what you find so we can spread the knowledge! Someone else is bound to have the same question as you.
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 5
Her zaman: 100
