Starts fill, stops, starts again, stops then drying fan starts, stops,
Whirlpool WDT730PAHZ0 roughly 4 yrs old. A day or so after a bad lightning storm and power outage in the area, my unit started acting crazy. It'll start filling, stops, then starts filling again, stops, drying fan kicks in, dispenser door opens, etc. I'm assuming a bad control board vs circulation pump or bad inlet valve due to the fact the drying fan is now starting at the beginning of any cycle. Also I tested continuity on the door latch, float switch. The diagnostic codes were F4,E3 then F6,E2 jumping between the two sets.
Bu iyi bir soru mu?
It's a control/main board issue
michael allen tarafından
Thanks Sir! I almost went for the sump motor assembly from a prior post. But that wouldn't explain the sporadic behavior of the drying fan.
Navyguy410 tarafından
