Display vertical and horizontal lining issue
Display lining issue no clear picture what is problem
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
7 Yorum:
@ratishulvekar post a picture of what your screen shows you, with your question. We need to see what you see Mevcut bir soruya görsel ekleme
tarafından Paylaş
To add to the above, we need a picture of the issue but if its really thin, maybe single pixel wide, lines that are (from what I've seen personally) usually green, red, or black - its likely that strip of pixels failing or physical damage. Which isn't often repairable without replacement of the LCD screen itself as far as I know, unfortunately.
Can't help diagnose without a picture though.
tarafından Paylaş
I have the same horizontal line issue
tarafından Paylaş
I am facing horizontal line issue can it be repaired or I have to change the panel.
tarafından Paylaş
@upasanadutta post a picture of what your screen shows you, with your question. We need to see what you see Mevcut bir soruya görsel ekleme
tarafından Paylaş
2 tane daha yorum göster
Yorum Ekle
