Why Monitor not working it shows an orange shade through,earlier it wa
Why Monitor not working it shows an orange shade,earlier it was showing vertical lines also.
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Ensure that all cables connecting your monitor to the computer or other devices are securely plugged in. Sometimes, a loose cable connection can lead to display problems.
If possible, connect your monitor to another device (such as a different computer or laptop) to see if the issue persists. This will help determine whether the problem lies with the monitor or the device it's connected to.
If you're using a computer, access the display settings and make sure the resolution and refresh rate are set correctly. Sometimes, incorrect settings can cause display abnormalities.
Outdated or corrupted graphics drivers can also lead to display issues. Make sure your graphics drivers are up to date. Visit the manufacturer's website to download and install the latest drivers for your graphics card.
If your monitor has multiple input ports (HDMI, DisplayPort, VGA, etc.), try connecting to a different port to see if the issue persists.
Inspect the monitor for any physical damage, such as a cracked screen or damaged cables. Physical damage could be causing the display problems.
Some monitors have a built-in reset option that restores the settings to their default values. Check your monitor's manual to see if there's a reset option and try using it.
Boot your computer into Safe Mode and see if the display issue still occurs. Safe Mode loads minimal drivers and can help determine if the problem is related to software or drivers.
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 56
