"Electric" noise from inside, doesn't last more than 5 minutes on batt
I just picked up an early 06 MBP for a fine price of nearly free.
Immediately I find that the battery doesn't last more than 5-10 minutes although the battery when the test button is hit shows complete bars. Then when plugged in and powered on the magsafe doesn't attempt to charge the battery. Before I ditched OSX for arch I snagged a system profile which shows this:
Diagnostics:
Power On Self-Test:
Last Run: 2/18/12 1:39 PM
Result: Passed
Power:
Battery Information:
Model Information:
Serial Number: SMP-ASMB012-346b-8b5
Manufacturer: SMP
Device name: ASMB012
Pack Lot Code: 0001
PCB Lot Code: 0000
Firmware Version: 0102
Hardware Revision: 0400
Cell Revision: 0100
Charge Information:
Charge remaining (mAh): 65337
Fully charged: Yes
Charging: No
Full charge capacity (mAh): 65337
Health Information:
Cycle count: 206
Condition: Good
Battery Installed: Yes
Amperage (mA): 0
Voltage (mV): 11886
System Power Settings:
AC Power:
System Sleep Timer (Minutes): 0
Disk Sleep Timer (Minutes): 0
Display Sleep Timer (Minutes): 10
Automatic Restart On Power Loss: No
Wake On AC Change: No
Wake On Clamshell Open: Yes
Wake On LAN: Yes
Display Sleep Uses Dim: Yes
Battery Power:
System Sleep Timer (Minutes): 5
Disk Sleep Timer (Minutes): 10
Reduce Brightness: Yes
Hardware Configuration:
UPS Installed: No
AC Charger Information:
Connected: Yes
Charging: No
I know that's about 59000-60000 mAh higher than reality would have it my question is this though:
GIven the noise, given the charge "info", given the fact that the battery doesn't actually charge after a no power death.
Is the battery actually bad?
What else could cause this failure to stay alive while on battery?
Hopefully in a month a friend of mine with the same laptop with zero issues will be back in town for me to test this battery in his machine.
-Beaver
Bu iyi bir soru mu?
