Why is camera not turn ON
Camera not turning on
Bu iyi bir soru mu?
@priyeshcamera if you are sure you have a good battery and if your battery case door functions properly, time to take it apart. Use this guide Sony Cyber-shot DSC-S2100 LCD değişimi to get into your camera. Once there, you need to check the motherboard. Make sure that the battery cables are properly attached and then check the fuse for continuity. One is the power fuse.
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 29
Her zaman: 1,333
4 Yorum
Hi @priyeshcamera,
Have you tried using new fresh batteries in the camera to see if it turned on, you didn't say?
jayeff tarafından
Yes, I already checked it
Priyeshcamera tarafından
Start problem not running
Binod Saw tarafından
Camera is 1year old please recover
Display is on but don't work tarafından
