Ana içeriğe geç
The Lenovo IdeaPad 3-15IML05 is a 15.6-inch laptop designed for everyday computing. It features Intel Core processors. The device model number is “15IML05”.
My screen is not displaying
When I switched on my laptop everything comes correct but the screen is not displaying, I have change the screen but still the same thing but when u connect with tv it displays on the screen of the tv and works perfect. What could be wrong with the machine
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
@stephenopoku when you changed the LCD display, you made sure that the new one is a good, working one and is the exact same model? Turn the computer on and make sure that it starts up. In a darkened room, use a flashlight and shine the beam at an angle against the screen. See if you can make out shadows or shapes. If you do, then it is your backlight that has failed. Since this is a new display, it would be either the backlight driver or the backlight fuse as well as the display connector. We would need to see your connector as well as your motherboard. At least we would need to know what make and model your motherboard is.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Stephen Opoku sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 8
Her zaman: 222
