Ana içeriğe geç
Released October 24, 2011 / 2.2, 2.4, or 2.5 GHz Quad-core Intel Core i7 Processor
405 Soru Tümünü görüntüle
Removing the glass from the trackpad
Hello to all think alike minds!!
I would like to know if its possible to remove the glass from the trackpad on macbook pro unibody
My main goal is that I'm trying to color my macbook like colorware does. only they are not available at my country so I decided to do it myself (half way done //colored the entire body and back of the screen) but i have no ideas how they do it on the trackpad.
from what i have figured so far is that the trackpad is colored(originally) much like the glass parts of the iPhone 4/4s.from the other side of the glass)
i don't know if its possible to remove the glass of the trackpad from the sensor pad it attached to and color it (without losing the sensitivity) but i do know that colorWARE does it somehow!
maybe on top of the glass ??
any thoughts and suggestions would be highly appreciated
Bu iyi bir soru mu?
Puan -1
4 Yorum
so not a single soul knows what I'm talking about?
tarafından
I have a few 'graveyard' trackpads here. I will take a look now and see if I am able to do this for you.
tarafından
Personal opinion - A colored film, transparent or not, with adhesive to it over the glass is going to be your best bet.
tarafından
How did you color it? I got a late 2008 macbook pro that is gonna be completely disassembled- it would be cool to color it while I am tearing it down! :)
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
You can heat up the glue that holds the trackpad together and then remove the glass form the sensor. you would then need to 'scrape' away the silver colouring that is painted onto the underside of the glass. I am not sure how you would then go about colouring the glass before re-seating the sensor back against the glass. Also I do not know how sensitive this would then be after this process.
You need to be very carefull doing this as the glass shatters into very very fine splinters if bent too much.
Hope this helps,
Wes
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Puan 0
Yorum Ekle
Yanıtını ekle
Art sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 2
Her zaman: 1,639
