My videocon ac showing e5 error
Some time My videocon ac showing e5 error
Bu iyi bir soru mu?
Bu iyi bir soru mu?
@sanjeevver27557 looks like your videocon ac is actually a split air conditioner. The error code E5 is an indoor fan fault. This could be a failed indoor coil temp sensor as well as a bad fan. Since it is intermittent I would replace the sensor first
Take a look at this video and see if it provides you with a resolution of this issue.
While you work on your AC, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy.
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 34
Her zaman: 2,981
3 Yorum
code L6 what's meaning
Nabil Dekess tarafından
E5 error videocon ac and out door not start problem
Hasnain Shaikh tarafından
@hasnainsha87010 did you check the answer?
oldturkey03 tarafından
