How to replace the cover over my camera lenses that cracked
I dropped my phone and the plastic or glass covering over top of the 3 camera lenses in the back of the phone cracked. Can that be replaced?
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Hi Judi,
Yes, indeed the lens covers can be replaced on your phone; they are available separately from the rear cover. Here's an example I ran across that should work.
With these the best bet is to remove the rear cover of the phone then clean out all the old glass from the original lens covers. Get the glue off with some isopropyl alcohol and stick the new covers on.
Alternatively if you wanted to spend a few more bucks you could just replace the whole rear cover as one piece; I found one for about $9 USD. You have to remove the rear cover in either case; this way you can just pop the new on one and you're done.
NEW Housing Cover For Samsung Galaxy A54 5G Glass Battery Back Cover Rear Door
Be sure and check any parts you buy against the actual model number of your phone; I see both Galaxy A54 and A54 5G being mentioned, but I can't tell if those are the same phone or not.
Anyway, I found a guide that may help get the rear cover off; it's actually for battery replacement but if you just follow the first step that'll get the rear cover off, which is all you need.
Manuals / Samsung Galaxy A54 5G / Battery
Good luck; let us know if you need any more information or assistance.
Bu yanıt yardımcı oldu mu?
Rear camera foot gaya hai
Google translation of Hindi text:
rear camera is broken
We will need to know more about what's going on with your phone in order to help. This particular question was about the glass over the camera lens; is that what is broken on your phone, or is the camera itself not working?
मदद के लिए हमें आपके फ़ोन पर क्या हो रहा है, इसके बारे में और अधिक जानने की आवश्यकता होगी। यह विशेष प्रश्न कैमरे के लेंस के ऊपर लगे ग्लास के बारे में था; क्या आपके फ़ोन में कुछ टूट गया है, या कैमरा ही काम नहीं कर रहा है?
Son 24 Saat: 13
Son 7 gün: 90
Son 30 gün: 408
Her zaman: 2,545
