My trunk won't open from the driver side
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Hi @donlee80811, do you mean that the lever by the driver's seat doesn't pop the trunk as it should? If this is the case, then the cable that connects the lever to the trunk latch has probably stretched. It may also have snapped/dislodged. This happens gradually over the years with cable latches, and you can usually fix it by adjusting the cable tension.
In to diagnose the issue, have someone sit in the driver's seat and pull the lever repeatedly. Then go around to the trunk and listen for the mechanism inside:
Give this a try and report back, we'll go from there
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 30
Her zaman: 287
