Ana içeriğe geç
Released in 2020, the Razer Blade 15" Advanced model is designed to provide gamers with powerful specifications and sleek aesthetics.
11 Soru Tümünü görüntüle
Ifixit 2020 Razer Blade 15 Advanced battery compatibility
Has anyone tried using the RC30-0248 Razer battery ifixit sells for the early 2020 Razer Blade 15 Advanced on the 2019 Razer Blade 15 Advanced that has the same RC30-0248 battery in it? Ifixit cannot confirm capability. Seems it should be fine.
Thanks
Replace a 5209 mAh battery compatible with your Razer Blade 15" 2020 Advanced model Laptop. 80.2 Watt Hours (Wh). 15.4 Volts (V). Part #RC30-0248. Görseli
Ürün
Razer Blade 15" Advanced Model Laptop Battery
$92.99
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
1 Yorum:
Did you ever figure it out?
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Using a battery not specifically confirmed by the manufacturer for your device can be risky. While the RC30-0248 battery may physically fit in both the 2019 and 2020 Razer Blade 15 Advanced laptops, there can be differences in voltage, capacity, and compatibility that are not immediately apparent. It's best to contact Razer's official support or check with Razer user forums to see if others have successfully used the RC30-0248 battery from iFixit in the 2019 model. It's essential to ensure compatibility to avoid potential damage or safety issues.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Bloatedbattery sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 10
Her zaman: 248
