Ana içeriğe geç
Lenovo ThinkPad Yoga 370, 360 derece menteşeye, çoklu dokunmatik AES destekli dokunmatik ekrana ve mobil bağlantı için isteğe bağlı LTE-A özelliğine sahip ince, hafif ve ultra taşınabilir bir 2'si 1 arada cihazdır. Model numarası: 20JH002AUS.
Device not switching on
  • Why is my PC not turning on and also not charging when connected to a power source?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
1 Yorum:
I need an urgent reply 😭😭
tarafından Paylaş
Yorum Ekle
1 Cevap
Filtre ölçütü:
@lanry you are not really telling us a lot here. Would be nice to know what you have checked and if anything has happened to this Thinkpad. Anyhow, I suggest you start with the basics for all devices and check a few things.
First you want to check your power supply. Make sure it has the proper voltages. Check to make sure connectors are not bend etc. After that, check the charging port. Clean it of any debris etc, use a few puffs of air to clean it out. Check the DC-in jack of your laptop. Make sure there is no corrosion, debris etc. that prevents it from working. If none of this works, get a ammeter and see if your laptop draws any amperage from the charger. After that, you need to check and see if your motherboard even gets power. For that of course, you need to open it up. Post Some good pictures of what you see. That way we can see what you see Mevcut bir soruya görsel ekleme
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Lanry sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 9
Son 30 gün: 18
Her zaman: 412
