Ana içeriğe geç
Xiaomi Redmi Note 10 Pro, Xiaomi tarafından Mart 2021'de piyasaya sürülen orta segment bir akıllı telefondur. 6,67 inç AMOLED ekrana, 108 MP ana kameraya, yan tarafa monte edilmiş parmak izi sensörüne, 5020 mAh pile sahiptir ve Snapdragon 732G işlemci ile çalışır.
Why my fingerprint does not work
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 3
7 Yorum:
Not show fingerprint option on setting and try all options are setting does not show and work fingerprint option
tarafından
How could i use fingerfrint senson
tarafından
Why my fingerfrint does not work
tarafından
I have this problem too
tarafından
2 tane daha yorum göster
Yorum Ekle
2 Cevap
Filtre ölçütü:
@bikashsah I suggest that you start by restarting your phone. Next, you want to check if your phone's software is outdated. Go to "Settings" > "Software update" and check for any available updates. Then you have to consider that Xiaomi may have turned the fingerprint sensor software off. Xiaomi has had a lot of bugs with their fingerprint sensor and software. Of course, then there is also the possibility of this being a hardware issue. If your sensor has failed, your software will most likely not find it.
Since iFixit does not yet have a guide for this, use something like this guide to replace it. A new sensor flex is readily available at many online stores. Use a vendor that appeals to you.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Try updating your fingerprint extension service. The update is in this site....
https://www.apkmirror.com/apk/xiaomi-inc...
Puan 0
Yorum Ekle
Yanıtını ekle
Bikash Sah sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 13
Son 30 gün: 62
Her zaman: 7,399
