Ana içeriğe geç
Released September 16th, Apple's "smaller" flagship smartphone features a 6.1" ProMotion OLED, a triple-lens rear camera system, 5G, and a newly designed "Dynamic Island" around the front-facing camera and top sensors. Successor to the iPhone 13 Pro.
Swapping 14 pro max logic board into 14 pro body
Hey, anyone managed to swap 14 pro max logic board into 14 pro body? Looks like both logic boards are of same size and they are swappable. Any long term issues ? Pls help, I have a spare body of 14 pro and logic board of 14 pro max I want to swap to .
Update (09/27/23)
I have attached the side by side image @dadibrokeit
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
I haven't opened up either of the two phones you've mentioned, but I can tell you this, that it's highly unlikely to work. The thing is, each logic board is custom designed for the phone it's in and the available space inside heavily determines the shape and size of the board and the placement of the connectors.
So far there have been no iPhones that have had compatible logic boards, and I see no reason to believe the 14 Pro series is any different. Not one single previous version of a Max or Plus model's board has been interchangeable with it's normal size sibling so it's unlikely the 14 will be either.
As I said, this is far from authoritative since I haven't held either board in hand, but based on Apple's history I feel confident stating that they won't interchange. I could be wrong and I'd be really interested to hear if I am, but I'm betting they won't fit.
Bu yanıt yardımcı oldu mu?
Puan 1
6 Yorum:
No , both logic boards are exactly same size and I even tried swapping it , but I want to know about any long term problems
tarafından
@idgaf5 That is interesting, Mani; it's certainly a first for Apple. One problem is that Apple keeps all the information on internal sensors and attached components to itself so there's no way of knowing if everything is going to match up. On one hand it would make sense to design one motherboard that can fit two phones, but on the other hand they've never done that before.
If they're physically the same, then the next obstacle would be the placement of the connectors. If they move even one of them then something isn't going to fit.
Can you take side by side pictures of the two motherboards so we can look them over?
tarafından
Attached the picture above
tarafından
@Mani did you manage to try swapping the logical board of 14 pro to 14 promax? What is the result?
tarafından
It worked well for one time from then on , screen is shrinking if i put 14 pro inside 14 pro max body and lcd. 😅
tarafından
1 tane daha yorum göster
Yorum Ekle
Yanıtını ekle
Mani sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 20
Son 30 gün: 80
Her zaman: 1,793
