Ana içeriğe geç
question regarding to the image
my question is how can I fix my samsung televsion that have sound but it does not have image
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 2
Yorum Ekle
2 Cevap
Filtre ölçütü:
Check the cable connections.
Change the input source.
Restart your TV.
Perform a soft reset.
Update your TV's firmware.
Reset your TV to factory settings.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
@lydiabicu we need to know the exact model for your TV. However, there are some general things you can check.
First you need to verify that you have no image on all inputs. Try all of those. If it remains dark, unplug everything that is plugged in the back of your TV. unplug the TV and push the power button for about one minute, then plug it back in. See if that resets your TV.
If it remains dark, turn the TV to a channel where you can hear the sound. Next, use a flashlight and shine the beam at an angle against the screen. See if you can make out shadows or shapes.
If you do, then it is your backlight that has failed. If you do not see anything, unplug your set and remove the back cover. Then visually check the boards for any obvious damage like domed or leaking capacitors. Check all the wiring and unplug the wires and plug them back in, make sure they are properly seated.
Post some images of all of your boards with your question. Use this guide Mevcut bir soruya görsel ekleme for that so we can see what you see. It is possible that this is either a power board issue or a T-con board issue.
For any in depth testing, you will need a multimeter. So, be ready to let us help you fix your TV :-)
Repair is War on Entropy!
Puan 0
Yorum Ekle
Yanıtını ekle
Lydia Bicu sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 22
Her zaman: 363
