Replacing 1TB SSD with 2TB SSD - not being recognised
I have ThinkPad X1 Carbon 7th Gen laptop. I am trying to replace a 1 TB SSD by cloning it to a 2 TB SSD. The clone completes successfully but when I install it I get a message that “A required device isn’t connected or can’t be accessed”. It reports “Inaccessible Boot Device”. I have tried various procedures recommended using a Windows 11 recovery usb drive, but to no avail. Has anyone experienced a similar problem, and if so, do they have any suggestions?
Bu iyi bir soru mu?
10 Yorum
Hi @mjkalba,
Is the SSD shown as being detected in the BIOS storage drive menus?
If not it may be a faulty drive or not connected correctly.
If it is then something went wrong when it was cloned
jayeff tarafından
It is detected by thw BIOS. It can be accessed from Command Prompt mode in the Windows Recovery environment and by other tools recovery medir.
mjkalba tarafından
@mjkalba
Just verifying that you cloned it using cloning software and not just copied over to it from the original drive?
jayeff tarafından
Cloned with Partition Magic, Macrium Reflect, and Aomei Backupper Pro. Same result with each tool..
mjkalba tarafından
@mjkalba
Have you checked that the cloned disc is set to "active" as shown in this link?
jayeff tarafından
5 tane daha yorum göster
