Knock sensor code is on and motor is thumping drivers side
Knock sensor says that it's out on the code and the motor is knocking and ticking up front driver side top
Bu iyi bir soru mu?
Bu iyi bir soru mu?
@tood it would be so useful if you would give us at least the year and the engine size for your Charger. The code you got from scanning would be great too. Anyhow, if you have a code that reports the knock sensor as failed and your engine is knocking etc, replace the sensor then rescan and re-evaluate.
Bu yanıt yardımcı oldu mu?
The problem could be:
It is best to figure out what the actual problem is so you don't waste money on parts you don't need.
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 17
Her zaman: 40
