Kernel Panic after housing replacement
Hey everyone,
Recently I posted about a housing replacement causing mic1 kernel panics in my iPhone SE 2020.
This first started when I purchased a new housing,battery and screen for my mams old SE 2020, however once I completed the repair process it was kernel panicking every 3 minutes.
I assumed it was an issue with that phone and left it for a few weeks.
Coincidentally my friend also has the same phone and was in need of the same parts so I said I'd fix it for him. I was very careful removing everything, using IPA to weaken adhesives etc however the same issue persisted.
I assumed maybe I broke the charging port when removing it, although unlikely in both phones and the same goes for the logic board however I was very careful with them too.
And what makes it even weirder is when I moved the parts from the original SE into my friends old housing it works perfectly??
So is it the housing causing the Kernel panics? is it the wireless charger possibly? I scuffed that up quite a bit when putting it in the new housing and then removed it once I suspected that but same issue occurs (Not sure if lack of qi charger causes kernel panics).
I'm very confused by it all. Any ideas?
Thanks
Bu iyi bir soru mu?
