Why fingerprint not working
how to fix fingerprint not working
Bu iyi bir soru mu?
@kelvinleorecide first you need to make sure that it is enabled in the settings menu. Go to Biometric, then Fingerprints and setup your prints. If the reader is not even being seen, then it is possible that you have a failed reader. Of course, you can also try to start your phone in safe mode and see if that changed anything. Ihat would rule out that 3rd part software messes with your sensor. You could also try a factory reset. Just make sure that you have backed up all of your files and that you know/have all of your passwords and access codes.
To replace the sensor and since iFixit does not yet have a guide for this, use something like this video as your guide.
Now, if that does not repair your fingerprint reader, you will have to do a deeper check. Here is the Samsung flowchart for the Fingerprint Sensor not working
Use the search function of your PDF reader to locate the components to be checked, from this document A125 Component Layout
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 9
Her zaman: 84
how to fix this problem
Hizkyas tiro tarafından
My fingerprint is not working
Mpho tarafından
@mpho46253 have you checked and tried what was suggested in the original answer?
oldturkey03 tarafından
