Ana içeriğe geç
2. nesil Apple Silikon (M2 çip) ve 13,3" Retina ekrana sahip MacBook Pro 13" için onarım rehberleri ve talimatları. Model A2338. İlk olarak 15 Temmuz 2022'de, WWDC 2022'de MacBook Air M2 ile birlikte piyasaya sürüldü.
Screen Problem, blurred lines at bottom of screen.
Hello,
My Mac have developed some blurring at the bottom on the screen. It covers the entire width of the screen and is about 1/4" high.
I took it into Apple and they said it needed "screen controller" repair costing about $600.
Has anyone else had this issue and was able to perform a fix themselves.
Thanks
Andrew.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
1 Yorum:
Sadly its out of warranty !!!!!!
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
Ouch! Your system should still be under warranty!
Double check if it is, then go to anther Apple store or dealer as this should be a free repair!
Unless there is visible damage around the displays chin area I can’t see any reason to be denied.
Bu yanıt yardımcı oldu mu?
Puan 0
2 Yorum:
tarafından
@andrewusherwood - If its just outside the window by a few weeks I would still press Apple, But you need to lean on them a bit. Be pleasant but firm, escalate it up the food chain, I'm sure you should be able to get this fixed for free!
tarafından
Yorum Ekle
I have the same problem, just just happen just I made an upgrade to Sonoma, I a few weeks after. Now, I don't know if its is hardware problem, or is it an software/driver issue. How can I tell, and take appropriate. I reverted to the original OS that come with the laptop, but the issue still persist.
Hope some can help..
Thanks
Puan 0
1 Yorum:
@georgetuges - Plug in an external display, if the image is clean on it, it tells us your internal displays logic is damaged and you likely need a new display assembly.
tarafından
Yorum Ekle
Yanıtını ekle
Andrew Usherwood sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 12
Son 30 gün: 26
Her zaman: 1,003
