Ana içeriğe geç
Released in June 2017 as a successor to the Surface Pro 4. Also known as Microsoft Surface Pro 12.3". Model number: FJT-00001.
Can the digitizer cable in the display be repaired/replaced?
When opening the computer to replace the battery, I ended up damaging the digitizer cable on the LCD screen. Any way this can be fixed or replaced?
Screen works perfectly, lost the touch screen functionality though :(
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
I'm so sorry this happend! It looks as if the display cable is part of the display. Try pulling gently up on it, and if it doesn't work, I think you will need a new display. You might be able to find a cable somewere and solder it, but that would be very hard, if possable.
Bu yanıt yardımcı oldu mu?
Puan 1
2 Yorum:
I appreciate your suggestions. Replacing it does seem like the best option, as attempting to solder without the right equipment can be very challenging. Unfortunately, I don't have access to a microscope. I'll look into getting a replacement display and hope that resolves the issue. Thanks again for your help!
tarafından
@soryn no problem! Glad I could help.
tarafından
Yorum Ekle
Yanıtını ekle
Soryn sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 7
Her zaman: 139
