Ana içeriğe geç
4th Generation Apple AirPort Extreme Base Station (Model Number A1354)
AirPort Extreme base station connectivity help
I am currently trying to broadcast a pre existing Wi-Fi connection (I don’t have Ethernet) and alter the settings through my AirPort Extreme base station but when I set it up to connect to a network and then change the security to none the airport has to be soft reset to edit any settings All I am trying to do is broadcast a wep connection with no password
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Does your computer have an Ethernet port? You may not need anything but an Ethernet cable depending on the computer.
You do need to use the Apple AirPort application from a Mac to set it up and use an Ethernet connection. Once setup the settings are saved and don’t need to keep the system plugged in but if you loose power you could loose the settings.
Bu yanıt yardımcı oldu mu?
Puan 0
5 Yorum:
I use the iPhone airport setup app
tarafından
@thomas35549 - I vaguely remember it only worked on the newer units.
tarafından
I’m using the airport A1347
tarafından
@thomas35549 - Are you sure that’s the correct model number as that is a MacMini system Mac mini Late 2014
tarafından
Oops sorry I also own a Mac mini and get model numbers mixed up
tarafından
Yorum Ekle
Yanıtını ekle
Thomas sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 7
Her zaman: 116
