Ana içeriğe geç
Panasonic Lumix DMC-G7, Mayıs 2015'te piyasaya sürülen giriş seviyesi bir aynasız, değiştirilebilir lensli fotoğraf makinesidir. Makine 16 MP çözünürlüğe sahiptir ve 4K video kaydı yapabilmektedir. Model numarası dünyanın büyük bir bölümünde DMC-G7, Avrupa'da ise DMC-G70'tir.
None of the back buttons work
Have you found a fix for this? I ran into this exact same problem. Fixed a loose piece in the camera and now the buttons won't work.
Update (10/18/23)
The entire inside element that holds the lens as well as the sensor was loose. So the lens and sensor wiggled around. I took it apart and put in two small screws and that fixed the issue. At work we have 4 G7s, and theyre all slowly giving out.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
1 Yorum:
@joelvanbeek same camera Lumix DMC-G7? What part did you fix?
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
@joelvanbeek try the service code on your camera to see if there is an error code. Make sure that after your work on your camera, that both Flex cables are properly re-connected and that the mainboard is free of any corrosion etc. Also make sure that you check the connectors for the flex cables. Remove the cables and then restart them. Check the ends for any tears etc. Here is the SM Panasonic DMC G7 that will help you with the diagnostic as well as the service for your camera. Let us know what you find.
There is of course always a possibility that this is Firmware related, but check the parts etc. first.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Joel Van Beek sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 18
Her zaman: 420
