Right joystick snapped and needs replacement.
Is the Xbox One Elite Controller Series 2 Joystick compatible and if not do you know where to get some replacements?
Bu iyi bir soru mu?
Bu iyi bir soru mu?
It appears that they are not exactly the same. They use the same resistance potentiometer (10k ohm) but use s different type of pole (the part the joystick caps connect to) which would make the interchangeable joystick caps no longer compatible. As long as you are comfortable with desoldering and soldering in a new analog stick you can go with the ElecGear EL4 analog stick replacements available on Amazon.
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 2
Son 7 gün: 6
Son 30 gün: 15
Her zaman: 279
